Mpmaster line numbers?
DavidB
With the Mpmaster post I have turned off seq numbers.
Can I get this post to give me a "N" line number for each tool change and a count?
What I would like is N101 for tool 10 the first time tool 10 is called then N102 the second time tool 10 is called in the same program.
I noticed this section is post...
 #Misc variables
tcnt : 0 # Count the number of tool changes
toolcount : 1 # Tool counter for logic control
toolcountn : 0 # Next tool counter for logic control
toolcountp : 0 # Previous tool counter for logic control
tooltotal : 0 # Tool tool count
nexttool : 0 # Next actual tool
nexttp : 0 # Next tool plane
prvtp : 0 # Previous tool plane
counter : 0 # Counter
nstrlen : 0 # Length of string
last_op_id : 0 # Previous internal operation id
last_cuttype : 0 # Previous cuttype
stock_typ : 0 # Predator Stock Type
cyl_typ : 0 # Predator Cyl Stock Type
z_min : 99999 # Min Z
z_tmin : 99999 # Overall min Z
z_max : -99999# Max Z
z_tmax : -99999# Overall max Z
tapflg : 0 # Flag for tap cycle
sav_mi9 : 0 # Saved mi9 value
rotretflg : 0
compwarnflg : 0
sof : 1
miscvalon : 0
David this exact topice has been discussed, if you do a search I'm sure you'll find it.
How about just an N number at each toolchange?
Here's one that makes the N = T
Linky
Making it = is easy enough making it = to T =1 one if previously used is little bit trickier
Stork,
That's not what he's asking for, if I read it correctly.
My posts are set up the same way N only at tool change. He wants N = T and then if T is recalled to roll the N # up one.
What David is looking to do is, I think
N1 T1 first use
N11 T1 second use
N2 T2 first use
N21 T2 second use
N101 T10 first use
N102 T10 2nd use
The new X Mpmaster has a new switch called
tseqno that controls this very easily
[*]tseqno : 2 #Output sequence number at toolchanges when omitseq = yes
#0=off, 1=seq numbers match toolchange number, 2=seq numbers match tool number
It was outputing N1 instead of N10, but that's easy to fix
David,
I think for you to pull this off the way you describe you're going to have to create a table to store the already used N #'s and then compare them so you can get the output correct.
This thread might be of interest in being able to track your tool changes
Linky
[ 03-19-2006, 04:27 PM: Message edited by: jmparis ]
