HELP with drilling cycle
camgeneration
can someone please tell me why if i run this code alone the drill goes to the initial height between holes(1"), but if part of a bigger program is stays at final z depth between holes, (scraps centerdrill and part) banghead.gifcurse.gifbanghead.gifcurse.gif
N1 G00 G17 G20 G40 G80 G61.1 G90
N9010 M01
N9011 M08
N9012 T1 T3 M06 (DEFINE TOOL NAMES)
N9013 (MAX - Z1.)
N9014 (MIN - Z-1.412)
N9015 G00 G90 G55 X1.375 Y-1.188 S10000 M03
N9016 G43 H1 Z1.
N9017 G98 G82 Z-1.412 R-1.212 F30.
N9018 X.5
N9019 X4.33 Y-1.718
N9020 Y-.588
N9021 X6.017 Y-1.718
N9022 Y-.588
N9023 G80
N9024 M09
N9025 M05
I am running a mazak nexus 510c hs
There is nothing in that code or anycode that I am aware of will make a drill stay at the final Z height. The retract motion is built into the machine canned cycle, you simply define where it goes.
Make sure the "use clearance only on first and last holes" is unchecked and make sure your retract plane and clearnace heights will clear the part.
here is some of the code from before the drill cycle of the bigger program(it's part of a 3d program so i'm only posting the tail end.
N8995 X5.9211 Z-1.5833
N8996 X5.9029 Z-1.5793
N8997 X5.8849 Z-1.5747
N8998 X5.8671 Z-1.5694
N8999 X5.8495 Z-1.5634
N9000 X5.8321 Z-1.5568
N9001 X5.8284 Z-1.5554
N9002 X5.8246 Z-1.5544
N9003 X5.8208 Z-1.5536
N9004 G00 Z-1.4535
N9005 Y-2.4377 Z.5
N9006 Y-2.4378
N9007 M09
N9008 M05
N9009 G91 G28 Z0.
N9010 M01
N9011 M08
N9013 (MAX - Z1.)
N9016 G43 H1 Z1.
N9018 X.5
N9019 X4.33 Y-1.718
N9020 Y-.588
N9022 Y-.588
N9023 G80
N9024 M09
N9025 M05
N9026 G91 G28 Z0.
N9027 M01
N9028 M08
N9029 T3 T2 M06 (DEFINE TOOL NAMES)
N9030 (MAX - Z1.)
N9031 (MIN - Z-2.4691)
N9032 G00 G90 G55 X4.33 Y-.588 S2000 M03
N9033 G43 H3 Z1.
N9034 G98 G73 Z-2.4691 R-1.212 Q.25 F10.
N9035 Y-1.718
N9036 X6.017 Y-.588
N9037 Y-1.718
N9038 G80
N9039 M09
N9040 M05
N9041 G91 G28 Z0.
N9042 M01
N9043 M08
when i just pull the code out of the big program and run it by it's self, it does as it should, but as run as above (the same code rember) it stays at z -1.412, the stock starts at z-1.312. I am looking right at the programming manual from mazak and it looks right???? banghead.gif
it was originaly g81, which mazak calls spot drill, and only allows x,y,r,z doesn't even list feed rate as an option. I changed to g82 which is listed as drilling with the options for dwell and feedrate override for a final distance (I). both g81 and g82 do the same thing on the machine, ok by itself, milling across the part untill the tool breaks if part of a bigger program. g82 actually has a extra variable D which is distance from R to start of cutting. It is allowed to be omitted, and since i don't know how to modify the post to add this distance variable, i was allowing the start drilling point and the reference plane to be the same. just set it above the surface .1".
No ,really ,it is my fault .
Sorry .
I was in hurry ,working ,some heavy stuff and very
silly too (designer is dumba$$ )
I had no time to read very nessasary information and replies ,I thought this is a drill code ,why on earth the guy would post nonreliable code .
Next time I would be more accurate .
And cautious .
Sorry one more time .
My fault .
Nevermore
But if this is g18 it will move on Y axis
BTW ,in my deckel-maho you need to call g18 any time after the toolchange due to some parameter ,THAT ALLWAYS RESET IT TO G17 AT TOOLCHANGE (M6 actually macro program ,so no wonder )
May be you have such an option on your MAZAK TOO ?
I will look to see if there is a parameter, i kind of doubt it though, it definitly does not reset now. i think the machine gets confused with a g18 and a drill cycle, doesn't do it either way right. Didn't want to be nasty either but after a lot of stress and time getting the post edit free, and to have tools and workpieces scraped i was not a happy camper. it all comes out of my wallet being my own shop, and times for me are hard enough already without extra expenses and time.
