G05P10000 in Generic Fanuc 5X Mill post
DavidB
Where do I add
 phsmon               # High Speed Machining Contour Control On
if mi1$ = 1, pbld, n$, "G05 P10000", "(SGI ON)", e$ #DAV WAS HPCC
prv_mi1 = mi1$
lookahead_flg = 1
!mi1$
phsmoff #High Speed Machining Contour Control Off
if prv_mi1 = 1, pbld, n$, "G05 P0", "(SGI OFF)", e$ # DAV WAS HPCC
lookahead_flg = 1
!mi1$
to the Generic fanuc 5-axis post?
I put in her but it did not work?
# Start of File and Toolchange Setup
p_goto_strt_tl #Make the tool start up at toolchange
pfd_shft_inc
psign_ang_out
##### Custom changes allowed below #####
if use_clamp & (cuttype = 0 | opcode$ = three | opcode$ = 16), #dav
p_lock = zero
s_lock = zero
pbld, n$, s_slock, e$
pbld, n$, s_plock, e$
if stagetool <= one, pbld, n$, *t$, "M6", e$
if n_tpln_mch > m_one, #Toolplane mapping mode
#Enter your mapping scheme here...
pg68_map
pbld, n$, "G43", *tlngno$, *zabs_s, e$
pbld, n$, *sg00, pwcs, "X0.", "Y0.", *zabs_s, e$
pcan1, pbld, n$, *sgcode, *xabs_s, *yabs_s, *p_out, *s_out, strcantext, e$
else, #5 axis and regular mode ( n_tpln_mch = -2)
if cut_ra_head & use_g45, #Swap xout and yout based on offset axis
tloffno2 = tlngno$ + g45_of_add
pcan1, pbld, n$, *sgcode, pwcs, *sgabsinc, *yout, *p_out, *s_out,
*speed, *spindle, pgear, strcantext, e$
pbld, n$, "G45", *tloffno2, *xout, e$
else,
pcan1, pbld, n$, *sgcode, pwcs, *sgabsinc, *xout, *yout, *p_out, *s_out,
if stagetool = one, pbld, n$, *next_tool$, e$
p_lock = one
s_lock = one
pg68
pbld, n$, *xout, *yout, *zout, scoolant, e$
else, pbld, n$, "G43", *tlngno$, *zout, scoolant, e$
prv_mi1 = mi1$
lookahead_flg = 1
!mi1$
lookahead_flg = 1
!mi1$
##### Stop custom changes #####
