Cantext Question: Long Post Thanks for Reading
crazy^millman
Well what is weird is I was on the right path when I tired this months ago. I did not realize how close I was till I figured it out today. I will post up what I did just cleaning everything up now to make it look good.
Yeah James I quit caring a long time ago what people said or thought me there is only one person I need to please and he keeps me around for some reason. rolleyes.gifrolleyes.gifrolleyes.gifbiggrin.gifbiggrin.gifbiggrin.gif
Ok so like I said I was close and Tim helped point me in the right direction.
First off how to handle it in the Cantext:
#P wait code output Start at P10 Increments by 10 and is placed by default at the Home positions.
if cantext$ = 20,
pwait_10
Then the logic:
pwait_10 # Added thanks to Tim Johnson
if mi10$ = 1,
if pwcodes = sav_pwcodes,
pwcodes = pwcodes + 1
sav_pwcodes = pwcodes
pbld, n$, *swcode, e$
else,
if pwcodes <> sav_pwcodes, pwcodes = sav_pwcode
And the strings:
# Select Turret Call Codes
sp00 P00 #Dummy Wait Code
sp10 P10 #P wait code
sp20 P20 #P wait code
sp30 P30 #P wait code
sp40 P40 #P wait code
sp50 P50 #P wait code
............... <----Removed for space
sp770 P770 #P wait code
sp780 P780 #P wait code
sp790 P790 #P wait code
sp800 P800 #P wait code
swcode #Target for string
fstrsel sp00 pwcodes swcode 41 -1
Then Added here:
ltlchg$ #Toolchange, lathe
toolchng = one
gcode$ = zero
copy_x = vequ(x$)
pcc_capture #Capture LCC ends, stop output RLCC
c_rcc_setup$ #Save original in sav_xa and shift copy_x for LCC comp.
pcom_moveb #Get machine position, set inc. from c1_xh
c_mmlt$ #Position multi-tool sub, sets inc. current if G54...
prdbturret, e$
ptoolcomment
comment$
if home_type < two, #Toolchange G50/home/reference position
sav_xh = vequ(copy_x)
sav_absinc = absinc$
absinc$ = zero
start_xh = vequ(xh$)
pmap_home #Get home position, xabs
ps_inc_calc #Set start position, not incremental
#Toolchange home position
if home_type = one,
pbld, n$, *sgcode, pfxout, pfzout, pwait_10, e$ #<---- Added wait codes
mtlchg$ #Toolchange, mill
toolchng = one
gcode$ = zero
copy_x = vequ(x$)
prdbturret, e$
ptoolcomment
comment$
absinc$ = zero
if home_type = one,
pbld, n$, *sgcode, pfxout, pfzout, pwait_10, e$ # <----- Added Wait Codes
pl_retract #Retract tool based on next tool gcode, lathe (see ptoolend)
cc_pos$ = zero
if home_type = one,
xh$ = vequ(start_xh)
ps_inc_calc #Set inc.
pbld, n$, psccomp, e$
#if css_actv$ & css_end_rpm & not(lathe_stop | synch_flg | n1_gcode = 1003 | n1_posttype <> posttype$ | n1_spindle_no <> spindle_no$),
#pspindle
#prpm
pcan1, pbld, n$, *sgcode, pfxout, pfzout, [if drop_offset, *toolno], pwait_10, e$ #<--- Added Wait Codes
if lathe_stop | synch_flg | n1_gcode = 1003 | n1_posttype <> posttype$ | n1_spindle_no <> spindle_no$,
pbld, n$, pnullstop, e$
else,
#Retract to reference return
pbld, n$, `sgcode, psccomp, e$
if home_type = m_one & drop_offset, pbld, n$, *toolno, e$
pspindle
prpm
pcan1, pbld, n$, *sg28ref, "U0.", [if y_axis_mch, "V0."], "W0.", strcantext, e$
if home_type > m_one & drop_offset, pbld, n$, *toolno, e$
pnullstop, e$ #<--- Added for Sync Spindles at ends of sync turning R.D.B. 1-4-08
if mr5$ = 1, pwcodes = 1 #<--- Added R.D.B.
prpm #Output for start spindle
speed = speedrpm
if posttype$ = two, #Lathe mode spindle
if speed = zero,
pbld, n$, pfspindle_l, e$ #RPM = '0', output just an 'M05'
else,
if (opcode$ = 3 | opcode$ = 16 | opcode$ = 105) & nextdc$ = 3 & rigid_tap = 1,
pbld, n$, pgear, e$
pbld, n$, *sg97, e$
else, #<--- Added R.D.B.
if mi6$ = 0 & mi7$ = 0, #<--- Added R.D.B
pbld, n$, pgear, e$ #<--- Added R.D.B
pbld, n$, *sg97, *speed, [if toolchng, pfspindle_l], e$ #<--- Added R.D.B
pbld, n$, *sg97, *mr6$, [if toolchng, pfspindle_l], pwait_10, e$ #<--- Added R.D.B
else, #Milling mode spindle
#result = nwadrs(strp, speed) #Different letter than 'S' for mill spindle?
if (opcode$ = 3 | opcode$ = 16 | opcode$ = 105) & nextdc$ = 3 & rigid_tap = 1, pbld, n$, *sg97, e$
else, pbld, n$, *sg97, *speed, *spindle_m, e$
result = nwadrs(strs, speed) #Reset to 'S' for next single speeed output
!css_actv$ #Added (8/27/2002)
pcss #Output Constant surface speed
speed = g_speed
if css_actv$, pbld, n$, *sg9697, *speed, pspindle_l, !css_actv$, *prdbccsul, e$
else,
if css_actv$, pbld, n$, *sg9697, *speed, pspindle_l, !css_actv$, *prdbccsul, pwait_10, e$
!speed
Now there are other things done for the Slave/Master call outs for Surface Speed and Few other things, and I am glad to share if anyone has questions.
I'm glad you got it going Ron. Is it possible to go back to the v9 coolants option? I like the idea of making several coolant options, but there has to be a better way than using cantext. I wonder if it would be possible to create a 20000s parameter for the coolant. That would also give you up to 16 coolant commands instead of ten.
Well Tim you were a big help on this. I also learned that the machine wants the PCODE in increments of 10 not 1 so that made it easier than when I 1st started down the road to figure this all out. I just think it is weird this was never a thought to do since I know of 4 different shops in the area that have dual turret machines and Mastercam.
Ok next Release of this. I did not take into account operations before the operations that needed to be staged. The program I was testing with was a simple turn and burn prep op for heat Treat. So here is a little update and a little more information hope it help others.
#Cantext activated flags
pwcodes : 0 #P wait codes Added for Okuma Lathe RDB
sav_pwcodes : 0 #Place Keeper for Wait Codes Added for Okuma Lathe
sav_pwcodes5 : 0 #Place Keeper for Wait Code Sync when using Cantext
toolchng = one
gcode$ = zero
copy_x = vequ(x$)
prdbturret, e$
ptoolcomment
comment$
absinc$ = zero
if home_type = one,
if mr5$ = 1, sav_pwcodes5 = pwcodes #<--- This line keeps the start Pcode to Sync with operation
cc_pos$ = zero
if home_type = one,
#pspindle
#prpm
else,
pspindle
prpm
if mr5$ = 1, pwcodes = sav_pwcodes5 #<--- This keep it till it is needed for the next operation that will Sync cut with the Previous
The one thing about this method is you need to do the operations you want to Sync in order so the post will read them correctly if not it will be a mess.
  • 1 month later...
Ok guys my next installment of tweaks. I was getting my wait code one the line after the Place I wanted in I used after, and when I did it with they came out in front on the line of code which would not work. It was driving me crazy knowing the answer was easy just could not put my finger on it. I got it today. I switched to V9 coolant and that helped but caused other problems. Fixed that, but still could not get wait codes where I wanted it. I then moved the pcan1 to the place before strcantext in 3 places in the post.
Like so:
prapidout	 #Output to NC, linear movement - rapid
 if interp_flg & (abs(cuttype) = 4 | abs(cuttype) = 2) & cutpos2$ = 0,
 if abs(cuttype) = 4, #position C then XZ for approach to interpolation on the OD
	 pbld, n$, psgplane, pexct, psgcode, pcout, pcan1, strcantext, e$
	 pbld, n$, pexct, pxout, pyout, pzout, e$
 else,				 #position C and X then Z for approach to interpolation on the face
	 pbld, n$, psgplane, pexct, psgcode, pxout, pcout, pyout, pcan1, strcantext, e$
	 pbld, n$, pzout, e$
 else,
 if lap_start, #Force both X & Z outputs
	 pbld, n$, psgplane, pexct, psgcode, pfxout, pyout,
	 pfzout, pcout, pcan1, strcantext, e$
 else,
	 pbld, n$, psgplane, pexct, psgcode, pxout, pyout,
	 pzout, pcout, pcan1, strcantext, e$
 lap_start = no$
plinout		 #Output to NC, linear movement - feed
 #Output the Z after XY so the tool can move to position before plunging
 #helps for toolpaths not starting near the 3o'clock position
 if interp_flg & abs(cuttype) = 2 & cutpos2$ = 0,
 pbld, n$, psgplane, psgfeed, pexct, psgcode, psccomp, pxout,
	 pyout, pcout, pfr, pcan1, strcantext, e$
 pbld, n$, psgfeed, psgcode, pzout, pfr, e$
 else,
	 pyout, pzout, pcout, pfr, pcan1, strcantext, e$
pcirout #Output to NC, circular interpolation
 pyout, pzout, pcout, parc, pfr, pcan1, strcantext, e$
Now my last task with this post sync 3 operations together. I have an idea where I will use another mr to hold a value where I can then use a different cantext call to starting counting my wait code for one operation from that to sync up with my 3rd operation. If all works I will post up my results.
$LK97580.MIN%
G14
(LOWER TURRET)
(MACHINE	 - OKUMA LU-15)
(CUSTOMER	 - GOODRICH LANDING)
(PART #	 - 901-036-422-103 REV NC6)
(MODEL #	 - 901-036-422-103 REV NC6.MCX)
(PROGRAMMER - RON
(PROGRAM NAME - LK97580.MIN)
(DATE - FEB. 25 2008)
(TIME - 9:31 AM)
(PROGRAM REV - N/C)
(TOOL - 1 - DDJNR-164D - DNMG-432 - OFFSET - 0 - INSERT - DNMG-432 - HOLDER - DDJNR-164D)
(TOOL - 2 - DDJNR-164D - DNMG-432 LOWER - OFFSET - 0 - INSERT - DNMG-432 - HOLDER - DDJNR-164D)
(TOOL - 6 - OD FINISH LEFT - 35 DEG. - OFFSET - 0 - INSERT - VNMG-431 - HOLDER - MVJNL-164D)
G13
(UPPER TURRET)
(TOOL - 1 OFFSET - 1)
(DDJNR-164D - DNMG-432 INSERT - DNMG-432)
G0 X20. Z20. P10
N1 T0101
G18 G95
G50 S3000
G97 S750 M03 P20
G96 S320 G110 P30
G0 X1.566 Z4.66 M8
G1 X1.466 F.014
Z4.1137
G3 X1.4494 Z4.0816 L.0663
G1 X1.318 Z3.9631
Z-.0712
X1.4594 Z-.0005 P40
G0 Z3.9569
X1.4255
G1 X1.338 Z3.9812
X1.17 Z3.8296
Z-.0712
X1.3114 Z-.0005 P50
G0 Z3.8234
X1.2775
G1 X1.19 Z3.8477
X1.022 Z3.6961
Z-.0712
X1.1634 Z-.0005 P60
G0 Z3.6899
X1.1295 P70
G1 X1.042 Z3.7142 F.005
X.874 Z3.5626
Z-.0712
X1.0154 Z-.0005 P80
G0 X1.53
M9
G0 X20. Z20. P90
M05
M01
G14
(LOWER TURRET)
(TOOL - 2 OFFSET - 2)
(DDJNR-164D - DNMG-432 LOWER INSERT - DNMG-432)
G0 X20. Z20. P10
N2 T0202
G18 G95
G50 S3000
G97 S750 M03 P20
G96 S320 G110 P30
G0 X1.7129 Z3.9327 M8
G1 X1.538 Z3.9812 F.014
X1.37 Z3.8296
Z-.0712
X1.5114 Z-.0005 P40
G0 X1.5649
Z3.7992
G1 X1.39 Z3.8477
X1.222 Z3.6961
Z-.0712
X1.3634 Z-.0005 P50
G0 X1.4169
Z3.6657
G1 X1.242 Z3.7142
X1.074 Z3.5626
Z-.0712
X1.2154 Z-.0005 P60
G0 X1.53
M9
G0 X20. Z20. P70
M05
M01
(TOOL - 6 OFFSET - 6)
(OD FINISH LEFT - 35 DEG. INSERT - VNMG-431)
G0 X20. Z20. P10
N6 T0606
G18 G95
G50 S3000
G97 S750 M03 P20
G96 S320 G111 P30
G0 X1.446 Z4.76
G1 Z4.66 F.005 P40
Z4.1294
G3 X1.4371 Z4.1109 L.0406
G1 X.854 Z3.5387
Z-.04
X.9954 Z.0307
P50
G0 X20. Z20. P60
M05
M02
Here is sample code with the above changes as posted no hand edits:
As you can see with 3 operations my codes start over and it here where I do have to edit the program, but at least they are were I can do something pretty easy with them.
[ 02-25-2008, 12:34 PM: Message edited by: Crazy^Millman ]
Another step closer to my puzzle here. Added a mr4$ and if you place the number in here before the next operation you want the P codes to change it will increment it correctly if you are keeping up with your wait codes through your creation of them using the cantext method I have been using. Here is the line of code I added to end of pl_retract part of the post:
      if mr5$ = 1 & mr4$ = 0, pwcodes = sav_pwcodes5 #<--- Added for Sync Spindles at ends of sync turning R.D.B. 1-4-08
else, pwcodes = mr4$
Again unedited code looks like so:
$LK97580.MIN%
G14
(LOWER TURRET)
(PROGRAMMER - RON
B)
(TIME - 10:18 AM)
(PROGRAM REV - N/C)
(TOOL - 5 - DDJNL-164D - DNMG-432 - OFFSET - 0 - INSERT - DNMG-432 - HOLDER - DDJNL-164D)
(TOOL - 3 - DDJNL-164D - DNMG-432 - OFFSET - 0 - INSERT - DNMG-432 - HOLDER - DDJNL-164D)
(TOOL - 4 - OD FINISH LEFT - 35 DEG. LOWER - OFFSET - 0 - INSERT - VNMG-431 - HOLDER - MVJNR-164D)
G13
(UPPER TURRET)
G0 X20. Z20. P10
N1 T0101
G18 G95
G50 S3000
G97 S750 M03 P20
G96 S320 G110 P30
G0 X1.566 Z4.66 M8
G1 X1.466 F.014
Z4.1137
G1 X1.318 Z3.9631
Z-.0712
X1.4594 Z-.0005 P40
G0 Z3.9569
X1.4255
G1 X1.338 Z3.9812
X1.17 Z3.8296
Z-.0712
X1.3114 Z-.0005 P50
G0 Z3.8234
X1.2775
G1 X1.19 Z3.8477
X1.022 Z3.6961
Z-.0712
X1.1634 Z-.0005 P60
G0 Z3.6899
X1.1295 P70
X.874 Z3.5626
Z-.0712
X1.0154 Z-.0005 P80
G0 X1.53
M9
G0 X20. Z20. P90
M05
M01
G14
(LOWER TURRET)
G0 X20. Z20. P10
N2 T0202
G18 G95
G50 S3000
G97 S750 M03 P20
G96 S320 G110 P30
X1.37 Z3.8296
Z-.0712
X1.5114 Z-.0005 P40
G0 X1.5649
Z3.7992
G1 X1.39 Z3.8477
X1.222 Z3.6961
Z-.0712
X1.3634 Z-.0005 P50
G0 X1.4169
Z3.6657
G1 X1.242 Z3.7142
X1.074 Z3.5626
Z-.0712
X1.2154 Z-.0005 P60
G0 X1.53
M9
G0 X20. Z20. P70
M05
M01
G0 X20. Z20. P80
N6 T0606
G18 G95
G50 S3000
G97 S750 M03 P90
G96 S320 G110 P100
G0 X1.446 Z4.76
G1 Z4.66 F.005 P110
Z4.1294 P120
G1 X.854 Z3.5387
Z-.04
X.9954 Z.0307 P130
G0 X20. Z20. P140
M05
M01
G13
(UPPER TURRET)
(TOOL - 5 OFFSET - 5)
(DDJNL-164D - DNMG-432 INSERT - DNMG-432)
G0 X20. Z20. P160
N5 T0505
G18 G95
G50 S3000
G97 S750 M03 P170
G96 S320 G110 P180
G0 X1.4069 Z3.3962
G1 X1.2655 Z3.4669 F.014
Z4.085
X1.396
X1.5374 Z4.0143 P190
G0 Z3.3962
X1.2764
G1 X1.135 Z3.4669
Z4.085
X1.2855
X1.4269 Z4.0143 P200
G0 Z3.3962
X1.1459
G1 X1.0045 Z3.4669
Z4.085
X1.155
X1.2964 Z4.0143 P210
G0 Z3.3962
X1.0154 P220
G1 X.874 Z3.4669 P230
Z4.085
X1.0245
X1.1659 Z4.0143 P240
G0 X1.564
G0 X20. Z20. P250
M05
M01
G14
(LOWER TURRET)
(TOOL - 3 OFFSET - 3)
G0 X20. Z20. P160
N3 T0303
G18 G95
G50 S3000
G97 S750 M03 P170
G96 S320 G110 P180
G0 X1.564 Z3.3962
X1.4301
G1 X1.2887 Z3.4669 F.014
Z4.085
X1.396
G0 Z3.3962
X1.3228
G1 X1.1813 Z3.4669
Z4.085
X1.3087
X1.4501 Z4.0143 P200
G0 Z3.3962
X1.2154
G1 X1.074 Z3.4669
Z4.085
X1.2013
X1.3428 Z4.0143 P210
G0 X1.564
G0 X20. Z20. P220
M05
M01
(TOOL - 4 OFFSET - 4)
(OD FINISH LEFT - 35 DEG. LOWER INSERT - VNMG-431)
G0 X20. Z20. P230
N4 T0404
G18 G95
G50 S3000
G97 S750 M03 P240
G96 S320 G110 P250
G0 X1.564 Z3.3962
X.9954 P260
G1 X.854 Z3.4669 F.005 P270
Z4.095
X1.396
X1.5374 Z4.0243 P280
G0 X20. Z20. P290
M05
M02
I am really close to making this do what I seen Esprit do with their Sync codes. No simulation, but can't have it all can we.
Same principle expect it is posted as one program and the G13 and G14 divide the programs in the machine to the upper or lower turret depending on the code used.
The last code posting fixed some of my problems for syncing 3 operations, but then screwed up my operation after that unless I put a number in at the mr4 places which then does work, but was working so that it took the last pcode and then keep that number and increment it from there now it reset back to zero. This is such a pain and really testing my patience today.
