Someone care to explain this one??
crazy^millman
This one has really got me scratching my head today. I can post this file and I get 2 different outputs all the time. Sometimes I get X positive outputs like I want and sometimes I get negative X output like I done want and even get a different turret selection altogether.
Here is the different programs posted 1 minutes a part from the same file using the same post.
$LK88950.MIN%
G14
(LOWER TURRET)
(CUSTOMER - ADD CUSTOMER)
(PROGRAMMER - RON
B)
(DATE - SEP. 18 2007)
(TIME - 6:40 AM)<---- Notice the time
(TOOL - 1 - OD ROUGH RIGHT - 80 DEG. LOWER TURRET - OFFSET - 0 - INSERT - CNMG-432 - HOLDER - DCGNR-164D)
(TOOL - 1 OFFSET - 1)
(OD ROUGH RIGHT - 80 DEG. LOWER TURRET INSERT - CNMG-432)
N100 G0 X20. Z20. N100 P10
N110 T0101
N120 G18 G95
N130 M109
N140 G97 S212 M03
N150 G0 X3.6 Z.143
N160 X3.5 Z.093
N170 G50 S3000
N180 G96 S200 G111
N700 G85 NAT1 D-.2 U.02 W.01 F.01
N710 NAT1 G81
N720 G0 X2.25 Z.093
N730 G1 G42 Z-.4078
N740 G3 X2.3388 Z-.4847 I.0888
N750 G1 X2.4238 Z-.5092
N760 G2 X2.455 Z-.5363 I-.0156 K-.0271
N770 G1 Z-3.0178
N780 G3 X2.4936 Z-3.0407 I.2762 K.2128
N790 G2 X2.51 Z-3.0618 I-.0231 K-.0211
N800 G1 Z-4.1212
N810 G3 X2.7675 Z-4.25 I.1288
N820 G1 X3.1275
N830 G2 X3.22 Z-4.2962 K-.0462
N840 G1 Z-4.505
N850 G40 X3.5
N860 G80
N100 G0 Z.093
N100 G0 X20. Z20. N100 P20
N110 M05
N120 M02
$LK88950.MIN%
G14
(LOWER TURRET)
(PROGRAMMER - RON
B)
(TIME - 6:41 AM)<--- Notice the time
G13
(UPPER TURRET)
G0 X-20. Z20. P10
N1 T0101
G18 G95
M109
G97 S212 M03
G0 X-3.6 Z.143
X-3.5 Z.093
G50 S3000
G96 S200 G110
G85 NAT1 D.2 U-.02 W.01 F.01
NAT1 G81
G0 X-2.25 Z.093
G1 G41 Z-.4078
G3 X-2.3388 Z-.4847 I-.0888
G1 X-2.4238 Z-.5092
G2 X-2.455 Z-.5363 I.0156 K-.0271
G1 Z-3.0178
G3 X-2.4936 Z-3.0407 I-.2762 K.2128
G2 X-2.51 Z-3.0618 I.0231 K-.0211
G1 Z-4.1212
G3 X-2.7675 Z-4.25 I-.1288
G1 X-3.1275
G2 X-3.22 Z-4.2962 K-.0462
G1 Z-4.505
G40 X-3.5
G80
G0 Z.093
G0 X-20. Z20. P20
M05
M02
Any suggestions for my sanity are greatly welcomed. Since I am ready to throw everything in the Dumpster. Now this is the weird part to get correctly posted code all I have to do is go into the tool and just go all the way to the set-up and draw the tool not changing anything 3 times and it will give me positive results. If I do the same thing again 3 times I get negative results.
Anyone got some ideas I am all ears.
Ron,
Not sure what you are using in your post, but start looking at some logic that may modify the sign of X. Dia_mult, scase_ strings, etc.
Depending on if you are reading parameters or not, maybe something going on with creation of the OPS file.
Another thought is if you have logic where you are checking the equality of values, there may some small difference in the decimal precision and in one case it reads true and then the other false.
I'll be glad to give it a try here if you need help.
Jim
Well just happened again new file same family of parts. Now here is the fix. I just need to edit the tool not changing anything. Go to the set-up and it will now make the operation dirty even though nothing is changed. Now you repost and the X moves now post out as X positive like they are suppose to.
Here is the same NC doing the above method:
 G13
(UPPER TURRET)
(TOOL - 5 OFFSET - 5)
(VHR 211 10 4 - VIPV .0938 .04675 INSERT - VIPV .09375 .04375)
G0 X-20. Z20. P150
N5 T0505
G18 G95
G97 S516 M03
G0 X-2.5915 Z-2.6439
G50 S2500
G96 S350 G110
G1 X-2.32 F.004
G0 X-2.5915
Z-2.5946
G1 X-2.32
G0 X-2.5915
Z-2.6932
G1 X-2.32
G0 X-2.5915
Z-2.5453
G1 X-2.32
G0 X-2.5915
Z-2.7425
G1 X-2.32
G0 X-2.5915
Z-2.496
G1 X-2.32
G0 X-2.5915
Z-2.7918
G1 X-2.32
G0 X-2.5915
Z-2.4467
G1 X-2.32
G0 X-2.5915
Z-2.8411
G1 X-2.3207
G0 X-2.5915
Z-2.3974
G1 X-2.32
G0 X-2.5915
Z-2.8903
G1 X-2.333
G0 X-2.5915
Z-2.3481
G1 X-2.32
G0 X-2.5915
Z-2.9396
G1 X-2.361
G2 X-2.333 Z-2.8904 I-.3076 K.1142
G0 X-2.5915 Z-2.8903
Z-2.2988
G1 X-2.3226
G0 X-2.5915
Z-2.9889
G1 X-2.4073
G2 X-2.361 Z-2.9396 I-.2845 K.1635
G0 X-2.5915
Z-2.2495
G1 X-2.4023
G3 X-2.3226 Z-2.2988 I-.027 K-.0626
G0 X-2.5915
Z-3.0382
G1 X-2.4767
G2 X-2.4073 Z-2.989 I-.2498 K.2128
G0 X-2.5915 Z-2.9889
Z-2.1742
X-2.5398
G1 X-2.3984 Z-2.2449
G3 X-2.31 Z-2.3121 I-.029 K-.0672
G1 Z-2.6614
G0 X-2.6105
Z-3.1122
G1 X-2.4691 Z-3.0415
G2 X-2.31 Z-2.8255 I-.2536 K.216
G1 Z-2.6035
G0 X-2.5398
G0 X-20. Z20. P160
M01
Now like it suppose to be:
M01
G0 X20. Z20. P150
N5 T0505
G18 G95
G97 S516 M03
G0 X2.5915 Z-2.6439
G50 S2500
G96 S350 G111
G1 X2.32 F.004
G0 X2.5915
Z-2.5946
G1 X2.32
G0 X2.5915
Z-2.6932
G1 X2.32
G0 X2.5915
Z-2.5453
G1 X2.32
G0 X2.5915
Z-2.7425
G1 X2.32
G0 X2.5915
Z-2.496
G1 X2.32
G0 X2.5915
Z-2.7918
G1 X2.32
G0 X2.5915
Z-2.4467
G1 X2.32
G0 X2.5915
Z-2.8411
G1 X2.3207
G0 X2.5915
Z-2.3974
G1 X2.32
G0 X2.5915
Z-2.8903
G1 X2.333
G0 X2.5915
Z-2.3481
G1 X2.32
G0 X2.5915
Z-2.9396
G1 X2.361
G2 X2.333 Z-2.8904 I.3076 K.1142
G0 X2.5915 Z-2.8903
Z-2.2988
G1 X2.3226
G0 X2.5915
Z-2.9889
G1 X2.4073
G2 X2.361 Z-2.9396 I.2845 K.1635
G0 X2.5915
Z-2.2495
G1 X2.4023
G3 X2.3226 Z-2.2988 I.027 K-.0626
G0 X2.5915
Z-3.0382
G1 X2.4767
G2 X2.4073 Z-2.989 I.2498 K.2128
G0 X2.5915 Z-2.9889
Z-2.1742
X2.5398
G1 X2.3984 Z-2.2449
G3 X2.31 Z-2.3121 I.029 K-.0672
G1 Z-2.6614
G0 X2.6105
Z-3.1122
G1 X2.4691 Z-3.0415
G2 X2.31 Z-2.8255 I.2536 K.216
G1 Z-2.6035
G0 X2.5398
G0 X20. Z20. P160
M01
I can duplicate this 100 times one 4 different computers with X2MR1SP1 and it is really a pain!!!!!!!!!!!!!!!!!!!!!! Yes QC with the latest release.
First off I am not crazy as I thought, thanks to Jim Evans and Steve Arteman for pointing out what is going here.
When you do an operation you have to check your axis combinations on the operation when you are using the lower Turret. Here is a Picture of what mine defaulted too: TooL_upper_to_start.jpg
Here is what it should be:
So you need to check this everytime you do anything to the operation or to the tool and post the operation. This seems to give the NCI and the information needed to the post a fit if this is not correct.
Thanks again to all of those who were helping me with this.
This is exactly what I just spent two days tracking down on an Okuma LR35. Now can someone tell me if I can lock the default to Axis combo left/lower. On the Okumas the G13 (upper turret) & G14 (lower turret) designate the direction of G2's and G3's. In other words a G2 posted out will read the same for both turrets. Depending on the G13 or G14 with determine the direction of arc.
Can someone please reccommend a good starting post for an Okuma LR35 OSP 5020-L control that suppports wait codes P10, P20, also live tooling for K values, I values.
Thanks in advance,
Greg.
