milltronics post modification help
jmayo
Hello all
we are haveing a couple of issues with our milltronics post first off it does not shut cuttercomp off when it is supposed to example being.
N110T2M06
N120G00X3.Y-3.S1146M03
N130G43H2Z3.M08
N140G00Z.1
N150G01Z-.125F6.9
N160G41D2X3.73F13.8
N170G03X3.Y-2.27R.73
N180G03X2.27Y-3.
N190G03X3.Y-3.73
N200G03X3.73Y-3.
N210G01X3. (g40 should go here)
N220Z.1F13.8
N230G00Z3.
N240G00Z.1
N250G01Z-.125F6.9
N260G41D2X3.75F13.8
N270G03X3.Y-2.25R.75
N280G03X2.25Y-3.
N290G03X3.Y-3.75
N300G03X3.75Y-3.
N310G01X3. (g40 should go here)
N320Z.1F13.8
N330G00Z3.
the next problem is tapping here is an example in this one g84 needs to be g88 and it needs feed per rev or .0769 for this tap how do i make this change
(TOOL TYPE: 1/2-13 TAP )
(OFFSETS: LENGTH H6 - DIAMETER D6)
N790T6M06
N800G00X1.Y-1.S152M03
N810G43H6Z3.M08
N820G84G98X1.Y-1.Z-.5R.1P0.F11.692
N830X5.
N840G80
N850G00G40G32M09
N860M30
a huge thank you to anyone who can help us out
thank you
Jonathan Mayo
Check in your post for the following
pccomp # Cutter comp output
if ccomp$ = 2, sccomp, tloffno$
if ccomp$ = 3, sccomp, tloffno$
sccomp # Insert this line if it is not there
I put it in our post to take care of the same thing
Always backup your post before modifications in case something goes wrong
Mastercam 8 through X4
This was in my post also
scc0 # cutter compensation state not changed
sg40 G40 # cancel cutter compensation # David 1-26-09
sg41 G41 # cutter compensation left
sg42 G42 # cutter compensation right
sg140 G40 # last linear move --> cancel cutter comp # David 1-26-09
sccomp
fstrsel scc0 ccomp$ sccomp 5 -1
Hope this helps you
the name of the post should be:
MILLTRONICS CENTURION_6 4X MILL.PST
and it has two tap cycles, tap, and rigid tap which will give the G88. if you give a peck value other than zero it outputs the Q value for peck tapping. It also does cutter comp on/off correctly, but any post should do that. I've never heard of mpcent6.pst V9 had a mpcent5.pst.
