X4 mpmaster dwell
Add a new fs2 statement for use with dwell$
#Default english/metric position format statements
fs2 1 0.7 0.6 #Decimal, absolute, 7 place, default for initialize (
fs2 2 0.4 0.3 #Decimal, absolute, 4/3 place
fs2 3 0.4 0.3d #Decimal, delta, 4/3 place
#Common format statements
fs2 4 1 0 1 0 #Integer, not leading
fs2 5 2 0 2 0l #Integer, force two leading
fs2 6 3 0 3 0l #Integer, force three leading
fs2 7 4 0 4 0l #Integer, force four leading
fs2 8 5 0 5 0l #Integer, force five leading
fs2 9 0.1 0.1 #Decimal, absolute, 1 place
fs2 10 0.2 0.2 #Decimal, absolute, 2 place
fs2 11 0.3 0.3 #Decimal, absolute, 3 place
fs2 12 0.4 0.4 #Decimal, absolute, 4 place
fs2 13 0.5 0.5 #Decimal, absolute, 5 place
fs2 14 0.3 0.3d #Decimal, delta, 3 place
fs2 15 0.2 0.1 #Decimal, absolute, 2/1 place (feedrate)
fs2 16 1 0 1 0n #Integer, forced output
fs2 17 1.4 1.3lt #Decimal, absolute, 4/3 trailing
fs2 18 0 3 0 3 #No decimal, absolute, 3 place(dwell)<------- I copied fs2 11 and removed the decimal points
Then change the format statement for dwell$ to use our new format: fs2 18
fmt  N  4   n$          #Sequence number
fmt X 2 xabs #X position output
fmt Y 2 yabs #Y position output
fmt Z 2 zabs #Z position output
fmt X 3 xinc #X position output
fmt Y 3 yinc #Y position output
fmt Z 3 zinc #Z position output
fmt A 11 cabs #C axis position
fmt A 14 cinc #C axis position
fmt A 14 cout_i #C axis position
fmt A 4 indx_out #Index position
fmt R 14 rt_cinc #C axis position, G68
fmt I 3 iout #Arc center description in X
fmt J 3 jout #Arc center description in Y
fmt K 3 kout #Arc center description in Z
fmt K 2 lead #Helical lead
fmt R 2 arcrad$ #Arc Radius
fmt F 15 feed #Feedrate
fmt P 18 dwell$ #Dwell <------------------------Change to fmt P 18
fmt M 5 cantext$ #Canned text
fmt 4 mr8$ #HSM
Mastercam Guru,
I was hoping you would chime in. I'm still not sure I understand what you mean. Do I just add this line:
then change this line:
thanks again
[chime in]
Here's a better way.
From the X4 Mpmaster post:
Search for dwell$. You should be able to find this section.
fmt P 11 dwell$ #Dwell <-- The 11 here refers to a fs2 statement number 11
fmt 4 mr8$ #HSM
Ok, we can see that dwell$ is using the format described by fs2 11
Search for fs2. You should be able to find this section.
# Format statements - n=nonmodal, l=leading, t=trailing, i=inc, d=delta
This means that dwell$ will be rounded to 3 decimal places(123.4567 would be 123.456 dropping the 7)
We want only the 123 part dropping the rest. fs2 4 describes what we are looking for.
So just change the 11 to a 4.
fmt P 4 dwell$ #Dwell <------change 11 to 4
fmt 4 mr8$ #HSM
You can't go wrong this way.
Nothing after the decimal can come out.
If you type in 2000.5 you will get 2000
[/chime out]
