Port roughing
DavidB
David,
That will depend on the port.
What I normally do is establish vectors and create Workplanes from them and then rough as much as possible in 3-Axis.
I can usually get through one side with 2-3 Workplanes.
Believe it or not, with some ports, simply drilling intersecting holes is sufficient.
David,
By creating a chain or a simple line segment for tool vector control,
you can limit the amount of 5-Axis articulation and prevent shank collisions and clearance issues.
As long as your setup is sound, you'll be able to match cut your finish
paths from the intake and exhaust sides and you won't see the overlap.
Remember that you do NOT want a nice smooth surface for an intake
port. You want the port to create a bit of "turbulence" to facilitate
the fuel-air mixture for combustion. If the surface finish is too smooth,
the fuel will have a tendency to adhere to the port surface and prevent a proper mixture.
I would try intersecting holes first and then rough with the advanced multiaxis port toolpath. I would finish with the same toolpath as well. I like to tilt the tool through a curve progressing from start to finish. It changes the pivot location of the tool as it gets dooper into the port. Here is one that I did in the past, though it was in an existing port.
